Spec 4 users come in.........
SSU'S Vice Mod
You'll be fine. I think most of the guys that do this run the iron disk from the stage 5 and the unsprung hub. MightyMouse says it drives fine, and I think 99SS-T too. I know Darkblue TA personally, he has that setup, says it drives fine, even slips about the same as his stage 3, but you can here the unsprung hub clang pretty good, not a concern, just means its working.
I haven't driven the stage 4 in his car, but did the S3.
LS1TECH Sponsor
On the street it's fine. On the track, well, I have welded 2 disks to the FW. Both at over 1000 breakin miles.
SPEC said it was cause I was in the water box heating up the ET streets. Go figure.
LS1TECH Sponsor
currently i have the spec 3 X-pad and love it but will be going with the 5 when it goes out . the 3f is actully more than the 5 and ive seen a few 3f's weld at the track . the newer stage 5's drive great other than a little squek on the shifts however it will hold almost anything you throw at it.
