Anyone have a picture of the throwout bearing?
I received many pieces for my t56 swap and the throwout was left in the pressure plate. I was just wanting to compare mine to a complete one to make sure it wasnt damaged or missing anything. Anyone have a picture of a throwout bearing either in the pp or by itself?
I'm confused. What do you mean the throwout bearing was left in the pressure plate. The TO bearing is mounted on the slave. Here's a pic from Ferocity02's post showing his clutch parts.
The original thread:
https://ls1tech.com/forums/showthrea...rowout+bearing
if the t/o bearing is in the pressure plate then you have an lt1 style clutch kit
they use a reverse pull style clutch
lt1 stlye PP
ls1 style PP
lt1 stlye PP
ls1 style PP
correct, the swap is an lt1 tranny. Tippman243, do you have a closer picture of the throwout for the lt1, maybe from the opposite side that the fork mounts on? thanks
