skeashy noise clutch
I just started hearing a squeashyyy sound when I let go of the cluthc , like if the clutch cable or something close to my foot needed lubrification
do you guys know what it could be and how long it would take to solve the problem
thanks
Cedric85745
thanks
Cedric85745
No clutch cable in the F-body. Does it sound squishy like fluid? If so, you shouldn't hear that unless you were under the dash messing around with the master. If it's a squeak, then I would spray some silicon spray on the clutch return spring and other joints and see if that fixes it.
Very common problem. It's more than likely the clutch return spring. It's tucked up underneath the dash pretty good so it will be easier to just pull the underside of the dash apart and spray it down. I'm pretty sure you will have to pull it apart, I can't think right now. At any rate, it's not hard.
