shift points?
Old 08-08-2005, 07:54 PM
ls2 bait's Avatar
Default shift points?
https://ls1tech.com/forums/generation-iii-internal-engine/362736-stock-cam-shift-point.html
not response there so ill try it here. thanx guys.
Old 08-08-2005, 11:08 PM
Shadow's SS's Avatar
For the 2000 camaros the fule cut out is at 6200 and they power out at 5500 stock. I noticed that you generaly drop about 1000 to 800 rpms per gear. Hmm but that obviously will change as you modify your car. Im told that the ls1 can rev up tp 8000 but I wouldnt test it past 6500 personaly
