If you bleed the slave, where does the fluid go?
Just wondering where the bled fluid goes when bleeding the slave? It seems like the only way to get at the bleed valve would be with a deep well socket, which would make it impossible to put a tube on the end of the valve...does the fluid just seep out...? Can someone please clear this up for me?
Thanks
Thanks
Originally Posted by NassyVette
Thats what I figured...just wanted to make sure...
There isn't any worry of the fluid getting on the clutch disk is there?
You ever tried the mighty vac method...I might give that a shot first. I can hardly bleed my brakes properly, this clutch bleed has me worried. All I've heard is that it's a nightmare
