Can those with the RAM power grip (non-HD) please step inside?
My new clutch is on the way and I just wanna clear a few things up before I start the install. For those who used the ram pg with a stock resurfaced flywheel...did you use a shim? If so what size?
The reason I ask is because the install directions on installuniversity.com say that it is basicaly trial and error to find the right spacing before the clutch engages properly. If I have to tear everything apart again right after I just put the stuff in, I'm gunna go ape ****.
So any tips from guys who have this clutch are much appreciated.
Thanks
Thanks
i had my stock flywheel resurfaced and didnt know it needed to be rebalanced, needless to say i had all kinds of probs not releasing, i would just buy a new flywheel and save myself the aggravation, just my .02cents
I installed my RAM PG almost a month ago and also used the stock resurfaced flywheel. When I put it back together is when I realized I needed to shim it as I could not shift into gear at high RPM's. I just used the shim that you can buy from RAM and it cured my problem...definately use a shim! It'll save you some time!
It seems like whether it needs a balance or not is really a crap shoot...
