UMI short shifter
UMI short shifter
At install university they have the install for Lous Short Stick, but I have the UMI short stick. Would the install be the same? and, if so, how hard would the install be for a 17 year old with 0 mechanical ability following the directions on InstallUniversity? Any tips or tricks would be greatly appreciated...
Wow! Install university makes it WAAAAAAY harder than it actually is. You don't have to remove the entire center console like that. All you have to do it unscrew the shift ****, remove the leather boot around the shifter, (it has little tabs that pull right out) unscrew 2 screws, put the knew shift handle in, put back together. It takes all of 5 friggin minutes.
