Clutch problems
My impression of the Spec3 is that it's a soft clutch (I have a buddy who has one, I've driven his car). The Cartek is a lot stiffer, and the RamVDS/910 (my current clutch) is even firmer than the Cartek.
How is it resting at the top of the pedal travel - is the pedal resting gently against the stop/switches - or is it not coming up far enough, or do you have to nudge it up?
Also, did you use any shims when you installed (spacer behind the slave cylinder)?
