wierd third gear problem
Ok did a search didnt find anything. Racing my buddies cobra last night(on the track of course) power shifted into second no problem started to pull on him powershifted third and thought I missed it looked down it was in third.except it was like it was in neutral and didnt want to come out of third. Got it out went back in worked fine. We went again same thing! Got it out and it worked fine again. Got on it today powershifted fine. WTF! new ram powergrip hd less than a month ago and replaced the slave as well. Have a new master havent put it in yet.any ideas? I was going to the track tomm. but not with no third gear
Originally Posted by 98TADRIVER
yeah mine sucks ***. i got a 98 ta and pops outta 3rd sometimes and grinds , 4th wont even go in, 5 grinds sometimes. I thought these Tremecs were HP transmissions. eeerrrr
It's all how you shift 'em. I just got my car out of the shop. Turns out I broke the shift fork, now I have a steel one. Back on topic; I would start with the master and do the tranny too. You won't know until the tranny has been disassembled.
It is possible to find a mystry gate between 2nd and 3rd. The linkage seems to lock up but selects no gear even though the stick is towards 3rd.This happens with a certain style of shifting . afaor those whe get it, it seems to happen frequently. An aftermarket shifter with a higher neutral-biasing spring load can help with this.
that is exactly what happened. Only happened that one night twice hasent happened since. I was banging third pretty hard. I will pick up a pro 5.0 shifter soon . Thanks alot you just took a load off my mind!
