where is the bleeder valve for my clutch hydraulics
https://ls1tech.com/forums/showthrea...ight=slave+pic
You see the two metal tubes going into the round part around the main shaft? Not the one with the red plastic cover but the upper one is your bleed screw. its a bitch to get to and to get a shallow socket on but just use a mini ratchet and you should be fine. I had to use a magnet to get the socket off b/c the 1/4 ratchet head wouldn't go all the way onto the socket.
And I even searched for ya
Good luck!
Good luck!
