Slave Cylinder connect
wrencher
You need to push the little white collar that is on the hose into the slave. This will release the hose from the locking tangs in the slave. Sometimes it helps to push the line into the slave & then push the collor in w/a screwdriver. Dont force& break the white plastic collar.
It has like a Green looking quick connect think on it with a little black ring that is on the hose not really understanding what to do. And how do i bleed the clutch can i do it like i am doing brakes or is there a different way to do it...
wrencher
Push the black thing into the slave's recepticle witha screwdriver. The line should release. The clutch can bleed like brakes it just wont take as long & is alot harder to get to the bleeder.
