Tranny Clutch / Squeak on Launch? Any Ideas? Textralia
For some reason on *some* mild RPM launches in traffic, my tranny / clutch will squeak. Its only for a second while the clutch is actuating. I dont think the clutch is slipping because i drop it into 6th at 35-40 mph and get on it; the car pulls up with no problems. 6k miles ago i did a textralia install and replaced everything clutch and hydraulic related. Also did the drill mod.
On a side note, When i 1st installed the clutch and had it on jackstands, i went to test it out. Started the car, pushed the peddal in, and put it in 1st. The wierd thing is the rear wheels turned slightly going into 1st. Once it was fully into 1st the wheels stoped. Is that a syncro issue? I am up for a rebuild! Please let me know what you guys think. Thanks!
I think i may have found my problem. Today i want under the car and i saw that the driveshaft is rubbing a little on my I pipe. Going to push it up out of the way and mark the driveshaft with a sharpie and take it for a spin. Hopefully thats my problem
