Weird Smell? What could it be?
Old 08-27-2005, 11:15 PM
nikeair042's Avatar
Default Weird Smell? What could it be?
When I drive the car around town, easy shifting, perfect. But if I do a hard launch, I mean, barely spinning the tires, like a 2,000 rpm and slip out the clutch quickly, I drive away and get a weird smell. Even if I drive for a little while after that normaly, I can still smell it. I thought it was rubber burning, but after I parked it and got out, the tires didnt smell. Could it be the clutch? Is this normal? It's the stock clutch. Would could be causing this burning smell?
Old 08-27-2005, 11:30 PM
co.6z28's Avatar
ur upper lip? j/p man its the clutch
Old 08-28-2005, 01:02 AM
02 BLK WS6's Avatar
Maybe the power scares the **** out of you when you get on it.
It's the clutch slipping and getting hot enough to burn and stink.
Old 08-28-2005, 01:29 PM
nikeair042's Avatar
I mean, I do it once in a blue moon, but nothing to worry about or be concerned about? Does it hurt the car at all?
Old 08-28-2005, 01:30 PM
nikeair042's Avatar
Is it normal for it to do that? Or does that mean the clutch needs to be replaced?
Old 08-28-2005, 03:42 PM
2K2WS6TA's Avatar
No it's not normal, it means your clutch is getting ready to need replacing, it may last awhile longer if you don't drive too aggressively but it'll need replacing soon
Old 08-28-2005, 08:24 PM
02 BLK WS6's Avatar
Time for an upgrade.Stock clutches are weak.
Old 08-28-2005, 09:08 PM
MRZ28's Avatar
uummmmm........ ccluutchh!!
Old 08-28-2005, 11:26 PM
nikeair042's Avatar
what is the best clutch to upgrade to? I am not looking to spend a lot, and its a daily driver, so, best bang for the buck.
Quick Reply: Weird Smell? What could it be?
