McLeod bellhousing install...need a 'lil help...
So, the instructions that came with it are worthless, as well as the bolts they send because they're not metric. I did some searching on this and found that Fireball had a good writeup on his install. As far as bolts go, I put the plate on, don't bolt it, put clutch in, and then put bellhousing on and bolt it all to block then I presume? It sure came with a lot of bolts, I just wanna make sure I'm gonna do this right here. So, I'm prolly gonna need to get shorter bolts to bolt it to block, or cut the old ones down? T.I.A., I'm gonna wait till I get some responses here before I finish up. Thanks again,
Brian
Brian
Make sure you check the total thickness/height with the plate to your stock bellhousing. https://ls1tech.com/forums/showthrea...05#post3507405
