master cylinder rod broke
Old 09-12-2005, 09:36 AM
Vertigo's Avatar
Default master cylinder rod broke
After doing the adj. Master Cylinder mod to the stock unit. I had the rod break on me. This was very unexpected due to the fact when i cut the rod to put the coupling nut on I noticed the rod was solid. To my surprise it turns out that the rod is only solid on the ends and in the middle it is hollow!!! After removing the hollow section of the rod i replaced it with another coupling nut. Better than new!
