Is this a broken tranny mount?
Old 09-13-2005, 10:43 PM
Nick D's Avatar
Default Is this a broken tranny mount?
I pulled into the parking lot at my work today and when I was slowing down, I noticed a banging sound coming from the shifter. It becomes only apparent when I am under 20 mph or when I push in the clutch (although I think this may be due to the fact that that is when my exhaust is at it's quietest). I can feel the vibration, or clunking, coming up through the shifter and it sounds like it's going to break. I don't notice it as much once I get going. Now would this be a tranny mount (hopefully) or is there something wrong with my tranny (again)? Thanks.
Old 09-14-2005, 12:25 AM
Nick D's Avatar
ttt...please
Old 09-14-2005, 01:14 AM
Loochy88's Avatar
sounds to me like it could be. I had something like that.. its either the transmission mount or one of the bolts that holds it is broken. Just go under there and disassemble the entire mount. Check all the rubber and all the bolts to make sure nothing is broken or cracked.
and if it is shot, [if youre not allready] consider a poly mount.
Old 09-14-2005, 03:08 AM
bmfcamaro's Avatar
what kind of torque arm??
Old 09-14-2005, 09:44 AM
Nick D's Avatar
stock torque arm
Old 09-14-2005, 11:32 PM
bmfcamaro's Avatar
you should be able to see the shifter moving if it does its probably the mount or a bolt to it.
Old 09-16-2005, 09:47 PM
GMendoza's Avatar
I have a similar clunking. I just went under the car and noticed that my torque arm mount is broken.
Quick Reply: Is this a broken tranny mount?
