View Poll Results: Spec 3 or Ram powergrip ?
Spec 3
17
58.62%
Ram powergrip
12
41.38%
Voters: 29. You may not vote on this poll
Old 09-15-2005, 02:14 PM
andres85's Avatar
Default Spec 3 or Ram powergrip
which is better for my 99 Corvette. mods are intake catback shifter and ls6 intake monifold. thanks
Old 09-15-2005, 02:48 PM
NassyVette's Avatar
Never had a spec but my new ram PG works great.
Old 09-15-2005, 03:10 PM
Kleeborp the Moderator™
MeentSS02's Avatar
Are you planning a good deal of future mods? If not, I'd be looking at the LS6 setup. FWIW, I have a RAM Powergrip HD, and I'll be going back to an LS6 setup since my car is a daily driver and won't see much more in the mod department. I'm just sorry I wasted my money
Old 09-15-2005, 10:43 PM
nostyta's Avatar
I'm running a Spec stage 3 in my T/A and have not had any problems with it.
Old 09-16-2005, 10:21 AM
NLinnear's Avatar
Spec all the way.
Old 09-16-2005, 11:00 AM
99blancoSS's Avatar
Textralia or OZ700 or aussie as its known as. Replaces everything, comes already balanced, grips like a ****! Smooth as silk. You should check into what all should be replaced when doing the install with your choices. The OZ700 comes with everything works great, no modifications required. Specs have had some problems, do a search. You'll read about specs disentegrating with 3k on them.
Old 09-16-2005, 11:21 AM
11SECDWS6's Avatar
Same here, spec 3 w/ 2k miles and no problems. Good clutch.
Old 09-16-2005, 11:27 AM
jbuerke142's Avatar
Me three.
Old 09-16-2005, 03:38 PM
SSblack98's Avatar
Spec 3 here, great so far...
Old 09-16-2005, 06:59 PM
ThirdGenLS1's Avatar
ram power grip here, feels great, no chatter after 500 miles, got about 8k on it right now everything sees good. Call up Jason at TSP great to deal with and good prices.
Justin
Old 09-17-2005, 09:30 AM
andres85's Avatar
thanks guys for your post.
Old 09-17-2005, 09:37 AM
JMBLOWNWS6's Avatar
My spec 3F is a sick puppy ! And it feels like stock and can take a beating. Im leaveing the line at 6k
https://ls1tech.com/forums/attachmen...chmentid=37716
Old 09-18-2005, 02:41 PM
2002z28's Avatar
spec stage 3 here. 4k miles thus far. the chatter is getting bette with every mile i put on it. it is very grabby.
Old 09-19-2005, 02:13 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Love my spec, don't have an opinion on Ram...never drove one.
Old 09-19-2005, 05:17 AM
Wicked_Hugger99's Avatar
Used to run a Spec 3 with my old H/C setup and had no probs whatsoever
Held up great
Old 09-19-2005, 08:17 AM
cantdrv65's Avatar
Post
I had the ram powergrip hd with 910 sintered iron disk....Grabbed and chattered like a **** definitely NOT street friendly. Just ordered a Spec 3 with heavy duty F-option....
Old 09-19-2005, 04:27 PM
Mr_president's Avatar
ya i have about 4000 miles on my spec 3 unfortunatly i think it sucks **** with my mods considering i race alot and i need a reliable clutch ...it slips like a moofo!!
Old 09-19-2005, 06:49 PM
02SOMWS6's Avatar
go with what ever letter spec 3 is the newest out. I have a spec 3I but there might be a better one out. Mine takes 5500 dumps with no problem. But if you search hard enough you will see that every clutch made for the LS1 sucks........LOL... so many people post up all there problems and blaim it on the clutch. Most that have had no problems change everything all at once and use the metal shim. It's funny......go search spec 3 and you will find a ton of post on how that clutch sucks, and the same goes for just about every other clutch out there. Good luck. Just make sure you get the newest version out.......not one that has been sitting on the shelf the past 2 years
Old 09-19-2005, 09:38 PM
GTObsessor's Avatar
about 2.5k on my RAM Powergrip and it's working great! Awesome clutch for a daily driver... I chose this over the Spec 3 cause I didn't want an on/off only clutch.
Old 09-20-2005, 08:53 AM
midwestcookiemonster's Avatar
Spec Stage 3
Quick Reply: Spec 3 or Ram powergrip
