Clutch Rattle
Clutch Rattle
After the new clutch/slave install I've noticed a rattle coming from the transmission. It sounds just like the noise a tranny makes when starting off from a stop at low speed and you're not giving it enough throttle (does that make sense?). The new noise mainly occurs in 1st and 2nd gear while driving at any speed. The noise goes away after a few seconds and then comes back again a few seconds later and keeps doing this repetively until I depress the clutch. I don't feel any abnormal vibrations, I only hear this rattle. Is this normal? It never did this before the new clutch/slave.
Thanks
Thanks
I have a 2000 Trans Am that does the same thing at low rpm in 1st and 2nd and pontiac told me it wasnt anything big and they didnt know why it did it but there was nothing wrong and if you keep it about 1000rpm when taking off it shouldnt do it
