bleeding........
Old 09-20-2005, 08:33 AM
triumphman's Avatar
Post bleeding........
Can anyone please explain how to properly bleed the hyd. clutch on a 01 f body using a mitevac, i have triied the std. method and my pedal still stays on the floor during hard acceleration,it works fine during normal driving. thanks
Old 09-20-2005, 08:49 AM
Ping King's Avatar
if it sticks on teh floor...chances are you hav a bad slave or a pressure plate.
i chased something around like this for months last year.
Old 09-22-2005, 07:45 AM
triumphman's Avatar
Thanks ping, anyone else?.............
Old 09-22-2005, 07:55 AM
hourang's Avatar
did you do the drill mod on the master?
Old 09-22-2005, 11:22 AM
sunsetta's Avatar
I hear alot about the drill mod on the master, what exactly is this mod? Can you tell me where I can get instuctions on how to do this? Thanks.
Old 09-22-2005, 11:48 AM
hourang's Avatar
www.installuniversity.com - go to install docs then master install /drill mod. Thats what i used to modify my stock master.
the drill mod increases the flow of hyd fluid to the slave. from the factory they had too small of an opening in the line causing the loss of fluid at high rpm shifting, causing you to misshift and loose pedal for a bit until you pump it up.
Old 09-23-2005, 08:21 AM
triumphman's Avatar
Yes i did the drill mod ,put clean fluid in and bled the system at the slave.
Old 09-23-2005, 08:33 AM
Bryan @ Speed Inc.'s Avatar
when my car was a 6spd i did reverse bleeding... it worked really well. took some time but was way easier and cleaner...........
get a vacuum pump w/ resivoir and stick the end of the tube down the line from the fluid resivoir and pump out all the air. you'll need quite a bit of extra/clean fluid for this. but it is way better than doing it at the slave in my opinion. if you're interested and want more details pm me about it.
Old 09-25-2005, 08:47 AM
AtlantaRTA's Avatar
A definite endorsement of Reverse Bleeding!!!! I know that people sometimes get them bled by pumping the peddle but it just doesn't always work. When you reverse bleed you either do what was mentioned or pressure bleed from the slave bleeder. A Phoenix Injector for about $100.00 will do the trick. Also remove the bolts on the Master, pull it out from the firewall still connected and lay it level on the frame. This lets the trapped air at the top go out the resevoir tube. It is not hard to do this with the master. Obviously try reverse bleeding first before you remove the master. It only takes about a quart of DOT 3 pumped through to bleed. That takes about 10 minutes in reverse. The slave may just be bad as mentioned. I even put a new Ram Powergrip in with a new slave and had similar problems at first. The slave was the problem and it eventually failed even at low RPMs. Replacement of the slave is the only cure for that. That's why I went with all McLeod Hydraulics and 9 months later NO PROBLEM!!!
Old 09-25-2005, 11:22 AM
MustangEater82's Avatar
So... just put the tip of the mighty vac in the resovoir and pump?
does it pull in any air form anywhere else, or as long as I pull bubbles, i am pulling air I am bleeding it out?
Old 09-25-2005, 09:15 PM
Hugger Z's Avatar
I use the small tip that came with the mityvac kit and bleed at the reservoir. Pump up to 25in/hg and I then crack the pedal a little and pump more if needed. I get air out of the system, but lately I think the master has worn out again because I can get air every time I pump the pedal...... DOH!
Old 09-29-2005, 06:10 AM
wannabels1ss's Avatar
hugger when u say crack the peddle...do u mean push it down a lil or crack the bleeder for the peddle...i think i understand just wanna be totally positive
Old 09-29-2005, 08:11 AM
hourang's Avatar
push tip of hose into the hole in the reservoir, make sure you have some brake fluid in the mityvac canister like 1/3 full, pump up to 10in/hg. pump clutch pedal and watch bubbles(air) come up the mityvac tube. when no more air bubbles come out, slowly release the pressure on the mityvac trying to not let the fluid all go out of the tube.
repeat process at 15 in/hg. then repeat again at 20, and again at 25. if your still getting more and more air bubbles out, just keep repeating steps at 25 until there are no more. there will always be tiny tiny bubbles in the fluid after doing this, its perfectly normal, were trying to get rid of the big bubbles here.
hope that helps.
Old 09-29-2005, 05:42 PM
thanks hourang i appreciate the excellent explination..im gonna try it tom hope it works..thanks again for the help
Old 09-30-2005, 08:02 AM
hourang's Avatar
no problem man this process worked very well for me, in fact, i did not bench bleed my master after the drill mod (required) and just used this method and its been working perfectly for the past 5k+ miles.
Old 09-30-2005, 05:04 PM
A-Bomb's Avatar
where can i get the mityvac?
Old 09-30-2005, 05:26 PM
i got my mightyvac at autozone for like 30 bux...thanks again for all the info guys..this method works so well i bleed the clutch on my hour lunch break and never even got dirty...but i found out after driving car to work that the hydralics slave is bad as the pedal went to the floor when i pulled up to work
Quick Reply: bleeding........
