Cluth Pedal Problem?
Bad Seller Warning!
I have a 96 LT-1 TA I just bought... and the clutch pedal is really hard to push down... And to top it down.. you have to push it down around 6-7" is there any fix to this or do i just have to deal with it ? Can it be adjusted to make it tighter?
well, on the lt1 car, you have one piece master and slave. the cause of heavy pedal can be different clutch with heavy pressure plate!!!
as far as adjustment, look under dash see if someone already put mcloud adjustable master in it(you can only adj the engagement of pedal, not the pressure.
if it still drive fine, just leave it.
the adj master is same as the one for ls1 car, go on their website and get it. its not really hard to install, its pain in the *** to remove the old one out and put new one in
