M6 Question
M6 Question
What are the gear ratios set up in my m6 3.42 SS
by that I mean how fast should I be going in first second third etc
for example first goes like 0-35 second goes from 0-65 i'm not really sure but i'd like to know at redline or like at 6.0 thanks guys.
Jesus
Jesus
in the gears and rear end section
https://ls1tech.com/forums/gears-axles/385675-what-s-top-mph-1st-gear-4-10-s-m6.html
Originally Posted by LS1 GG
I dont really know because I'm pretty sure when i'm shifting at 6k rpms i'm at 65 mph and it says that our cars hit 107 in third but that doesnt sound too right
only wasy you hit 65 is either if you were shiting at 7500k rpms on stock gearing....or you have 2.73s in the back and were shiting around 7k.
This is with 3.42's and 275-45-17 tires, now i'm pretty sure my first gear doesnt hit 50 mph
RPM 1st Gear 2nd Gear 3rd Gear 4th Gear 5th Gear 6th Gear
500 4 6 9 11 15 22
600 5 8 10 13 18 27
700 6 9 12 16 21 31
800 7 10 14 18 24 36
900 8 11 15 20 27 40
1000 8 13 17 22 30 45
1100 9 14 19 25 33 49
1200 10 15 21 27 36 54
1300 11 16 22 29 39 58
1400 12 18 24 31 42 62
1500 13 19 26 33 45 67
1600 13 20 27 36 48 71
1700 14 21 29 38 51 76
1800 15 23 31 40 54 80
1900 16 24 33 42 57 85
2000 17 25 34 45 60 89
2100 18 26 36 47 63 94
2200 18 28 38 49 66 98
2300 19 29 39 51 69 103
2400 20 30 41 54 72 107
2500 21 31 43 56 75 112
2600 22 33 45 58 78 116
2700 23 34 46 60 81 121
2800 23 35 48 62 84 125
2900 24 36 50 65 87 129
3000 25 38 52 67 90 134
3100 26 39 53 69 94 138
3200 27 40 55 71 97 143
3300 28 41 57 74 100 147
3400 29 43 58 76 103 152
3500 29 44 60 78 106 156
3600 30 45 62 80 109 161
3700 31 46 64 83 112 165
3800 32 48 65 85 115 170
3900 33 49 67 87 118 174
4000 34 50 69 89 121 179
4100 34 51 70 92 124 183
4200 35 53 72 94 127 187
4300 36 54 74 96 130 192
4400 37 55 76 98 133 196
4500 38 56 77 100 136 201
4600 39 58 79 103 139 205
4700 39 59 81 105 142 210
4800 40 60 82 107 145 214
4900 41 61 84 109 148 219
5000 42 63 86 112 151 223
5100 43 64 88 114 154 228
5200 44 65 89 116 157 232
5300 44 66 91 118 160 237
5400 45 68 93 121 163 241
5500 46 69 94 123 166 246
5600 47 70 96 125 169 250
5700 48 71 98 127 172 254
5800 49 73 100 129 175 259
5900 50 74 101 132 178 263
6000 50 75 103 134 181 268
500 4 6 9 11 15 22
600 5 8 10 13 18 27
700 6 9 12 16 21 31
500 4 6 9 11 15 22
600 5 8 10 13 18 27
700 6 9 12 16 21 31
500 4 6 9 11 15 22
600 5 8 10 13 18 27
700 6 9 12 16 21 31
So am I slower than I was with my 50s?
Originally Posted by Silas2k
I've never understood this... how does the tire height (40/45/50 etc.) affect anything? Is there one that you should want over the others? The reason I ask is because I got a set of tires for free (can't bitch, right) but their height is 40.
Also, the second number in a tire size (275/45/17) is what percentage of the width (275/45/17) the height is. Meaning that for the aforementioned size, the sidewall height would be +/- 123.75 mm (45% x 275). What is the complete size of your tires?
You are not necessarily slower, but your car may say you are.
Originally Posted by BrandonDrecksage
ignore what your speedo says if you change the tire height. a taller tire will have to use more rpms to go to the same speed....and smaller height tire will have to use less rpms to get to the same speed.
Originally Posted by MW2 Performance
Think you got it backwards, Smaller tires make the driveline spin faster to go the same speed, Larger tires have the reverse effect, they spin slower but still cover the same speed... Changing your tire size is basically changing your final gearing, like changing the gears in the rear end in a sence, Becuase changing the tire size effects the ratio's of all gears..
