Does having an '01 mean no drill mod req'd? Also textralia users inside please
Old 09-26-2005, 08:42 AM
Frost's Avatar
Default Does having an '01 mean no drill mod req'd? Also textralia users inside please
I have an 01 TA that is all factory but about to be built up with an FI setup...
I am going to get a textralia clutch, do I need to drill out my SC or am I good having an 01?
Will I need adjustable MC and SC?
This clutch needs to hold 700RWHP, does anyone have any experience with one at this level?
thanks for your time
Old 09-26-2005, 09:38 AM
lsp408's Avatar
the drill mod is for the line come off the master cyl, you can go to installuniversity for more info. as far as slave cyl, eventhough you have 01 car, when you buy tex clutch, the kit will include everything you need. the slave come with the kit is also the newest. so all you have to do is the drill mod. some people use adjustable master, i didn't. just make sure you get all the air out of system!!!
as far as power, mine only got about 400rwhp, it holds fine, i know here few people use this clutch and have exceed the power range and still hold good.
Old 09-26-2005, 09:51 AM
Frost's Avatar
I can't seem to find a power range.... 700RWHP is the boosted target on pump gas. With some race fuel on a friday night and the numbers are only gonna go up. Is this clutch up to the task?
Old 09-27-2005, 12:35 AM
Frost's Avatar
ttt
help me out, I need to get a clutch...
Old 09-27-2005, 04:06 AM
lsp408's Avatar
didn't i just answer your question???
Old 09-27-2005, 06:16 AM
Frost's Avatar
Not the second one....
It doesn't really help me to know that some users here have exceeded the power rating of the clutch, because I don't know what that rating is... What is the actual "power-rating" of this clutch? My 700rwhp is the pump-gas target with FMIC and meth. I want to know if I go up 2-5 more # on race fuel that I will still be covered I guess....
Old 09-27-2005, 12:43 PM
lsp408's Avatar
call this # and peter or jeff will answer you any question
