Flywheel install
Old 09-30-2005, 12:54 PM
tici's Avatar
Default Flywheel install
Both the crank and the flywheel have 6 holes for the bolts and one hole for nothing (??).
Do they have to be aligned?
There is no alignment pin or whatever to keep a specific position, but it seems logic to aligne them... or not?
Thanks - Stefano
Old 09-30-2005, 01:00 PM
MW2 Performance's Avatar
If i remember correctly they are zero ballance? Try doing a search on flywheel install and you might find it.
Old 09-30-2005, 01:15 PM
tici's Avatar
well... I normally use the search button before asking something...
I haven't find any post about this particular topic.
Maybe it's just obvious that the holes have to be aligned, but then it would be logic to have a pin
Old 09-30-2005, 01:41 PM
jdnz28's Avatar
yea i would like to know the same thing . when i did mine i just aligned the holes . thats the way it was and it seems to be right .
Old 09-30-2005, 02:20 PM
CashMoney's Avatar
Align the holes. I Thought the 7th hole had a small nipple that should have gone into that hole. But its been a couple years since I installed one on an LS1.
Old 09-30-2005, 04:51 PM
tici's Avatar
Thanks!
I knew it makes sense but I wanted to be sure
Quick Reply: Flywheel install
