Help with clutch
Help with clutch
My pilot bearing is going bad so I'm looking into a new clutch since I'm gonna have to pull the trans out, I leaning towards a Ram powergrip clutch but I don't know which one to get, I'm looking on summit and I see 26-Spline Shaft, 11 in. Disc, 10-spline shaft and 10.5in disc, what do I need? I have no idea. Also what brand pilot bearing should I get, and what else should I replace while the trans is off? I want to order the stuff off summit tonight. Thanks.
Also what is the drill mod that i keep reading about on this forum?
If your looking at Ram clutches, you can check with the sponsers to the right. If you want to go in another direction ie. Spec, I can help you out.
The drill mod is done to remove a restriction in the line that smooths out engagement for normal driving. Do a search and you'll find more info.
