Reverse Woes
Old 10-10-2005, 02:58 PM
ChicagoTransAm's Avatar
Default Reverse Woes
The other day I was going to back out of my driveway but ended up in 5th. So I pulled it out and tried again. Dammit! 5th. So, one more shot...this time giving the shifter a little extra *bump*. Slid over the rest of the way and I was able to put it in gear. No grinding or anything...just really tricky to get it to move that far. Any idears?
Old 10-11-2005, 03:25 AM
TTT? There is no SES light regarding this...so I am assuming it's not a bad reverse lock out solenoid
Old 10-11-2005, 01:03 PM
Bugsquawsher's Avatar
I wouldnt' assume that.
If the computor is seeing the right current going to the Solenoid then it wont' throw a code.
It might still be bad.
thats the only thing in there I can see giving you that trouble.
With light side to side Movement you can feel a detent on the left , then it will center, and then you can feel a little detent to the right
pushing harder you will feel another one to the right.
With the car off can you feel the two detents to the right ?
Old 10-11-2005, 05:20 PM
When going to the left, yes...there is a little tension. Nothing out of the norm. Going to the right...there is the same amount of tension until I reach the reverse area. Then in feels like I am trying to push it through mud. The closer I get to the right, the more tension is built up.
Old 10-11-2005, 06:08 PM
My bet would be on that solenoid then.
You can try to remove it and see if that fixes your problem.
