1998 z28 help
1998 z28 help
I have just recently replaced clutch master cylinder on this car. The slave/TOB/Clutch/PP were replaced around 10k ago by a local shop. After doing the master I have had a little trouble bleeding it, but after a few tries it has very good pedal pressure and engagement points. Now comes the bad part. I have good pedal, but a loud noise coming from the tranny when the clutch pedal is depressed and then a loud pop upon full pedal. Any ideas or opinions? This is my dd. Or if you're local I'll even throw ya some cash if you can fix it. I am tired of bathing in brake fluid. LOL
Thanks everyone
Thanks everyone
Update :
After pumping the clutch repeatly the POP sound is gone. Now I just have a loud squeak coming from the transmission as I push in or release the clutch pedal. Once again I am not losing any fluid that I can tell and not lost pedal pressure. But this noise is LOUD. any ideas anyone?
