mity vac to bleed clutch??
how the hell do you use this thing?? ive been trying to find directions on here...but havent had any luck... anyone know how to use the mityvac let me know please thank you
Simple;
Use the cone shaped attachment. Put the bottle in line with enough fluid for the hose to submerge in the bottle. Insert the cone at the base of the master, draw 18" of vacuum and watch the air bubbles come out. When the bubbles stop, release the vacuum, make sure there's enough fuid in the master to cover the cone before you remove it and your done.
Needless to say, make sure you don't spill any fluid on your paint, and wash the hoses and bottle when you're done.
