Master upgrade.
Old 10-17-2005, 12:10 AM
TransAmGT's Avatar
Default Master upgrade.
Ok i'm buying a spec III for my '00 along with the upgraded slave cylinder. I don't have to upgrade my master cylinder do I as long as i do the drill mod i should be find.
I have two friends with '00 and Spec III's and they are running the upgraded slave and stock master (no drill mod) and it's working fine. So i should be ok right or do i need to upgrade the master?
Old 10-17-2005, 02:54 PM
ArcticZ28's Avatar
You can try it without upgrading if you want and see how well it works. You may not need it. Or, you can just solve all problems before they have a chance to happen and replace the master while u're at it.
Old 10-17-2005, 08:44 PM
TransAmGT's Avatar
What is different..i was under the impression the 01/02's had the same master and needed the drill mod also!
Quick Reply: Master upgrade.
