what type of synthetic fluid to use in M6
Old 10-23-2005, 03:00 AM
YOUNG's Avatar
Default what type of synthetic fluid to use in M6
I want to change the fluid in my tranny and I want to use a synthetic fluid. What type do most of you recommend?
Old 10-23-2005, 03:47 AM
Nightclaw's Avatar
I've had Mobil1 synthetic ATF in my MN6 T-56 for 5 years now - seems to be working great!
Old 10-23-2005, 04:56 AM
YOUNG's Avatar
Default reply
That is actually the type of fluid I was thinking about running.
Old 10-23-2005, 10:55 AM
GreekGator's Avatar
actually, from what ive heard you should not run synthetic fluid in the T-56. i hope others will chime in with this though.
Old 10-23-2005, 11:12 AM
oange ss's Avatar
98-00 tranny's no
01-02 tranny's ok
Old 10-23-2005, 01:00 PM
trackbird's Avatar
My 2002 has been running Mobile 1 since 18,000 miles (it has almost 70k on it now). It works great for me.
Old 10-23-2005, 03:16 PM
Nightclaw's Avatar
When I first put Mobil 1 in my T-56 oh, around February of 2000, everyone said the same things: it'll shift hard! The gears will grind! Your synchros will disintegrate! You'll become flaccid...!
With 60k on my tranny and having been using Mobil 1 exclusively for the last six years and 55k miles, any ill effects have thus far failed to materialize. Shifts are smooth, the tranny's quiet, and well... I mean, what else can you expect out of a tranny, eh?
Old 10-23-2005, 04:15 PM
chucky2's Avatar
young- You may want to take a read through both of the threads below in their entirety...basically you'll have to form your own conclusions on this subject:
Ending the speculation: Blocker rings, who's had them fail?
Which T56 fluid?
Chuck
Old 10-23-2005, 06:38 PM
Mr_president's Avatar
well i have a 2000 t56 and its been rebuilt i just dropped mobil one synthetic shifts better then ever ....is this a bad idea should i drain it?!?!?
Old 10-23-2005, 07:49 PM
ls1 joe's Avatar
I recommend mobil 1 to all my customers. This is what I run in my cam only beast. There is no issues from what I have seen in the many I have rebuilt. Mobil 1 is recommended by me.
Old 10-24-2005, 05:22 PM
Fran D's Avatar
Likewise, I've used Mobil1 synthetic in my '00 M6 for the past 35K miles and there have been NO transmission issues whatsoever.
Now, the rear, that's a different story.
Old 10-26-2005, 12:45 PM
YOUNG's Avatar
Default reply
I will for sure read into the other forums about the fluid type. I was really thinking of using the Mobil 1 since I believe that they make the best motor oils. Thanks for all the input.
Old 10-28-2005, 10:51 AM
Formula 1's Avatar
Auto Zone, cheap, auto tranny fluid!
Old 10-28-2005, 01:14 PM
tirefryer's Avatar
Royal purple synchromax here. Shifts are much smoother than the ATF in it from the factory.
Quick Reply: what type of synthetic fluid to use in M6
