Help me make my stock master cyl adjustable
Old 10-26-2005, 06:30 PM
N3V3RL8T's Avatar
Default Help me make my stock master cyl adjustable
I read about this on these forums a few times but I did a search and cannot find any post on how to do this. I have a problem with my clutch not disengaging with a specII and resurfaced flywheel. I knwo about the shim, but want to try this before i have to drop the transmssion again... So if anyone could hook me up with a post on a tech article explaining how this is done i'll tell you "thanks a lot, and your a big help".
I just got a new tranny and i dont want to take any chances with hard shifts untill i have this problem fixed, thanks a lot, josh.
Also, i'd be cool if someone could hook me up with an article on how to bleed te thing too, thanks again.
Old 10-26-2005, 09:00 PM
SPEEDYws6's Avatar
https://ls1tech.com/forums/showthrea...aster+cylinder
I did mine similar to this except I didn't use a rod end... I cut the stock rod in two about an inch from where it mounts to the pedal, threaded the rod and put a coupler on the rod. Works like a charm.
Old 10-26-2005, 09:08 PM
N3V3RL8T's Avatar
will doing this allow my clutch to fully disengage?
Also, do you have to remove it each time you want to adjust?
Old 10-26-2005, 09:57 PM
SPEEDYws6's Avatar
I don't have to revome mine to adjust it. I just take the rod off the pedal and adjust the coupler. I'm not sure if you will have as much adjustability with this as you would a mcloed. I built mine because my clutch was not fully disengaging and it fixed it perfectly.
Old 10-26-2005, 10:52 PM
SUX2BU's Avatar
Mcleod adj master is the ****!
that is all.
Quick Reply: Help me make my stock master cyl adjustable
