Transmission problem or rearend?
Old 11-07-2005, 05:41 PM
Shutout's Avatar
Default Transmission problem or rearend?
Lately my tranny has been making a clunking sound when I put it into first gear. It doesn't do it all the time just once in awhile. Also when I let out the clutch I will here a clanking noise as if I let the clutch out to fast.The noises seemed to have increased since I put in my LCA's and ES mount. Maybe with these mods the car is a little less loose and just making normal noises sound more pronounced.Could it be a u-joint or the rearend? Is their anything I could check to help me sort this out?
Old 11-07-2005, 06:55 PM
DragonsPhyre's Avatar
Check tranny mounts.
Old 11-08-2005, 05:34 PM
Shutout's Avatar
I just installed an ES tranny mount about a week ago. The vibation is starting to go away!
