what brake fluid do you guys use in your hydrolics?
Old 11-20-2005, 12:57 PM
jerflash's Avatar
Default what brake fluid do you guys use in your hydrolics?
im just wondering what everyone uses becasue i went to the tack yesterday and car was launchin sick but i could not get into second because the clutch fluid is all black and burnt
what fluid do you guys use in high performance aps that wond mess up the seals or anything
thanks guys
joe
Old 11-20-2005, 01:41 PM
Rob
Rob's Avatar
Motul 600.
Old 11-20-2005, 01:44 PM
Samba242's Avatar
Valvoline synthetic DOT4
Old 11-20-2005, 02:45 PM
dailydriver's Avatar
Originally Posted by Rob
Motul 600.
Yup. This or GS610, Neo 610 or if you are crazy (and real rich) Castrol SRF!!
Old 11-20-2005, 04:55 PM
jerflash's Avatar
is the Motul 600 like a regular dot 4 fluid or is it something completly different
can it be mixed with other stuff?
do i ahve to start off with a completly dry system first?
thanks
joe
Old 11-20-2005, 05:02 PM
Mike K.'s Avatar
I use the same, fluid is pretty good I think even rated better than dot4 if I remember right? Only problem for me is the parts around the hydraulics keep failing
Old 11-20-2005, 05:39 PM
jerflash's Avatar
i actually just bleed my system and used Valvoline synthetic DOT4 because i had an unopened big bottle in my garadge and i needed to get that black **** out of my master and lines
everything is clear now for the most part and i also mityvaced it but got very little air out car is shiftin good now but the test is the strip
i will put a new slave in next time i do a clutch
then i will put some motal in probably
Old 11-20-2005, 06:58 PM
wrencher
wrencher's Avatar
I use the valvoline synthetic also, flush it regularly w/ the color starts to darken. Work great for me.
