T56 vs. Richmond Overdrive 6 speed
Old 11-20-2005, 05:38 PM
firefighter's Avatar
Default T56 vs. Richmond Overdrive 6 speed
Okay before you say it I just finished a search for about 30 min.
Now the question I'm looking to buy a motor/trans combo to do a swap into my Blazer X so I'm prolly gonna get a 6-speed (T56) but I was thinking if I'm gonna do all the mods to make the tranny fit in the first place I might as well do the better one. So which is it the T56 or the Richmond 6 speed? I've really never heard anything but good about them both. Thanks in advance for the opinions.
Old 11-20-2005, 10:28 PM
SUTTERERMAN85's Avatar
well the T56 5th and 6th are over drive gears and thbe richmond 6 speed only 6th is overdrive i believe. therefore you will have wider gears in the t56 but a lower cruise RPM. the richmond will have less "in between" each gear and a lower first gear i believe like 3.XX as compared to a ls1 t56 which is 2.66 i believe. 6th in a t56 is like .5:1 and i am not sure what the richmond is like .7:1 or so. havent ever been around a richmond before just know what i have read. it really depends on what you are going to use it for like hot rod, drag car, ect. i know that the T56 is a good tranny and is going to be cheaper prob than a richmond route. hope this helps you a little. all i know is that i have a 55 chevy in a barn with a dual 4bbl carb 396 and it will be getting a T56 when i get out of school. Big Blocks and 6 speeds are really cool.
nick
Old 11-21-2005, 07:44 AM
nice but I know you can pretty much order the Richmon how you want it my question is mostly about durability and availability I almost think the Richmond is tougher but the T56 can match it and beats it in availability.
Old 11-21-2005, 08:00 AM
oh well i was not aware of that, sorry. i would prob go the T56 route because of availabilty and it would be a bit cheaper. you can beef them up if you need to. i just went through my tranny about 2 weeks ago and put new bearings, syncs, and a steel 3/4 fork in it. they are pretty easy to work on and if you are going to have one you will need to know how to. is this going to be going into your xtreme? if thats the case with an ls1 why not go the T56. it all bolts up with factory stuff. just me .02
Old 11-21-2005, 08:17 AM
Yeah I think thats what is gonna end up happening... And man you don't have to apologize you're trying to help me out with the info you know and I appreciate it.
Old 11-21-2005, 10:14 AM
no prob. i have heard good things about the richmonds too, nothing bad at all. you know that nothing is really industructable though. a T56 will hold up well. i would just go that route cause of how easy they are to get, cost, and how easy it would be to mount to an LS1. BTW the xtreme would be sweet with an LS1. talk about a sleeper
Old 11-21-2005, 11:56 AM
LS1 AMX's Avatar
Probably depends on what you are really looking to do ... if street either will work fine ... If you are planning on racing ... Richmond IS NOT a racing trans ... a year or so ago we pulled one out of a Brand "X" 347 car, had maybe 6 passes and busted up all kinds of parts ... One quick trip and $$$ to Liberty gears and problem solved. Richmond trans is also pig heavy ... that's my 2 cents.
Old 11-21-2005, 03:08 PM
AMX Didn't realize they were heavier than the T56 thats something to consider. But aren't they based on NASCAR trannies?
Also Sutt I know it's gonna be a sleeper thats all part of my evil plan lookin to get about 400hp to the street it'll be my little snake killer I'm in the process of getting parts to upgrade the brakes and then gotta finish the suspension and on to the MOTOR
Old 11-21-2005, 04:41 PM
it will be sick. i have thought about doin something like that, but i am in school and its kinda hard to do you know. glad to see that you are doin brakes and susp. stuff also.
Old 11-21-2005, 05:00 PM
Sutt don't know what you're studying but let me tell you unless it's something really good it only gets a little easier once your out of school. Hell I'm doing this because I can't afford a Vette well I might be able to but then I wouldn't be able to put the baby seat in it.
Old 07-06-2020, 07:41 AM
Gerald Bryan Bailey's Avatar
Default T56 vs ROD 6
nick
A T56 is good for those guys bragging about having 4.56:1 rear gears, or something. A Richmond Gear 6 spd can be had with .85, .80, and .74 overdrive gears. 1st can also be as low as 4.01. One really really figure what they want and how they'll use their vehicle. 4.56 x .50 = 2.28, 2.73 x .85 = 2.32. 4.56 x 2.66 = 12.13, 2.73 x 4.01 = 10.94. These are but examples. Have fun chosing.
Old 07-06-2020, 11:09 AM
Mgill's Avatar
Good job bumping a 15 year old thread lol
Old 07-06-2020, 03:25 PM
stevieturbo's Avatar
Was just about to say ******* legend !! 15 years is a good one.
The following users liked this post:
JF74chevelle (07-06-2020)
Old 07-11-2020, 12:07 AM
CattleAc's Avatar
In before GAtsma again...oh, wait, you guys beat us both...
Quick Reply: T56 vs. Richmond Overdrive 6 speed
