signs of failing master cylinder?
Old 11-27-2005, 02:34 PM
WS6FirebirdTA00's Avatar
Default signs of failing master cylinder?
what are the signs for a clutch master cylinder on it sway out? i dont think my problem is related at all but i am just curious. thanks
Old 11-27-2005, 05:41 PM
wrencher
wrencher's Avatar
Well seeping fluid from the actuation rod inside the car would be a sign. An inconsistant pedal, or a pedal that doesnt build pressure well (have to pump)Or a pedal that bleeds off when held down.
Old 11-27-2005, 08:43 PM
ok thanks
Old 11-28-2005, 07:05 PM
any shape way or form a bad master could make a clutch slip or destroy a clutch? my spec is shot and i want to make sure before i order a new clutch. doesnt appear to have any leaks at all, just a squeaky clutch pedal when i let off. fluid is full and has been to the best of my knowledge. pedal feels inconsistent but the clutch still feels shitty. when i say inconsistent it still grabs at the top just sometimes it only catches when the clutch is all the way out. i can push the pedal down just barely and can change gears also.
Old 11-28-2005, 09:29 PM
wrencher
wrencher's Avatar
High release is usually a worn clutch but not always. If it started as a low engagment & ended up high I would be suspicious.
But a consistantly high release/engagement can be blamed on the hydraulics.
I would suggest getting a new slave & a an adjustable master w/ the drill mod done to the line. Maybe something besides spec as well.
Old 11-28-2005, 10:49 PM
well i have an 01-02 slave and did the drill mod on the stock master...i just want to rule out any hydraulic problems before i get a clutch. the car shifts great, hell i can shift fast putting hte clutch down 1/4 of the way lol
Old 11-29-2005, 11:38 PM
anyone else?
Old 11-30-2005, 09:22 PM
to the top. i can run WOT in 1st gear and light the tires up and second pulls pretty damn hard most of the time, so im kinda stumped
Old 12-01-2005, 07:57 PM
to the top, surely someone can help me a little more, please?!
Old 12-01-2005, 08:43 PM
keliente's Avatar
I'm not sure how much $$ you have to throw around, but why not just buy a new master from GM? I think it's $125 or so. If it doesn't fix the problem, at least you replaced it before it failed anyway (which it will eventually )
Old 12-01-2005, 08:45 PM
i have no money to throw around thats the problem. right now im not working, if it was summer time i would have put a new master in there weeks ago to try it. definately wont hurt, but if it is infact the clutch im screwed cause i just spent money i didnt have and then i have to spend more lol.
just trying to see if anyone had some similar issues and the master helped. what makes me feel its the master is it is almost inconsistent. somedays it will bit and spin the tires in 2nd no problem and others it feels sluggish if i hit it in 2nd. but then again it could be a clutch lol
Old 12-01-2005, 09:20 PM
HOSS's Avatar
Driver Mod is necessary...lol
Old 12-01-2005, 09:31 PM
you can kiss my white *** lol next time your car brakes ill be over there, only to laugh haha
Old 12-01-2005, 09:45 PM
wrencher
wrencher's Avatar
You need a clutch. If the master's OE I'd recommend doing it also,specially if your modded & run it hard.
Old 12-04-2005, 04:38 PM
JCurtin's Avatar
my step dad says that to friends all the time
Quick Reply: signs of failing master cylinder?
