Shaking starting off in first
Old 12-03-2005, 04:16 PM
1BaDaSS's Avatar
Default Shaking starting off in first
I have a 99 SS m6 and when I start off in first gear from a stop the stick shift shakes. I'm not sure if it's the transmission or what... or is this normal?
Old 12-03-2005, 04:26 PM
1999 SS's Avatar
try giving it a little more gas and lifting off the clutch pedal quicker so it engages sooner, otherwise i think it pretty common. ive seen it on some cars and not on others unless your describing something else.
Old 12-03-2005, 04:43 PM
LS1obsession's Avatar
Do you have an aftermarket clutch? Is it like a "shutter/chatter" or just a slight shake?
Old 12-03-2005, 07:08 PM
1BaDaSS's Avatar
It's a shaking feeling. Actually the whole car feels like it shakes/shutters until the clutch is totally disengaged. It's not a real big shake but it's there.
Old 12-04-2005, 12:22 AM
prostock_bigblock's Avatar
I have ecxactly the same prob guys , I just installed spec3 week ago the mcloed master and 2001+ slave and a pilot bearing .
Wondering WTF is going on?
Old 12-04-2005, 08:43 PM
mrhzk35404's Avatar
How does your tranny mount look?
Old 12-04-2005, 08:51 PM
SUTTERERMAN85's Avatar
could be a pilot bearing(mine was gone) and it f'ed up my inputshaft bearing too. i have a stock clutch so this is just an FYI
Old 12-04-2005, 10:34 PM
BLK UUS-6's Avatar
Most guys after installing an aftermarket clutch do the drill mod on the master line regardless if the master is new. I had the Ram Powergrip HD installed and also had some chatter when it was new but that was because its a much more agressive clutch and the catch point was different with the new adjustable master. Try give it more gas and possibly do the drill mod.
Old 12-05-2005, 03:34 PM
bastien's Avatar
I used to experience this on my stock clutch. It would shake pretty bad when leaving from a stop in 1st gear. I took it to the shop and they resurfaced the flywheel, and it fixed it. If you give it more gas though, you won't be experiencing any shakes/shutters. my .02
Old 12-05-2005, 03:41 PM
98TADRIVER's Avatar
mine does the same thing! only at low rpm. its because the stage 3 is basically in or out, not much in between to play with. Cant slip the clutch like the stocker. no worries from what ive heard its normal. try taking off at a slightly higher rpm.
Old 12-05-2005, 06:25 PM
__________________
Thanks god I guessed so.
well it been couple of days and the clutch started to be much smother day after day or I am possibly get used to it.
How would you guys recommand the drill mod?
Old 12-05-2005, 07:10 PM
93transam's Avatar
Mine does the same thing, with the RAM Powergrip. Just give it a little more gas.
Old 12-05-2005, 07:22 PM
I think it must be the characteristic of a high perfomance clutch.I had a RAM race clutch in my stock t/a from the previous owner and it would shake and shatter and all sorts of stupid ****. The engagement was terrible, especially at lower rpms. At higher rpm's it was better, but nowhere smooth. Then I could not longer take it. I took the RAM out and put a stock oem LUK clutch back in. The pedal was about 20 lbs lighter. The engagement was smoother, but not perfect. I was told to help break in it by shifting into 3rd and and bascially "fluttering" the clutch. In other words have it in third let(not for very long though, I think I did it twice) the clutch out about 3/4 and run the rpm's up to 2,000, but not stalling the vehicle, you wont' be moving either. I guess this would basically burn any oils of on the surface. This seems to help and the engagment is really smooth.
