Hard to get into first gear.
The past 2 days my car has been very diffiult to get into first gear, and grinds if i try to shift gears faster than normal. What's wrong with it?
Do you have someone to help you bleed the system? If so, just make shure you keep plenty of fluid in the reservior-check it every two bleeds. See how it does and repost. Also, you can check the rod where it comes into the car on the clutch master cyl. Check to see if your low fluid is caused by it leaking at the back of the clutch mastercyl.
uhh dont really have anyone to help. Neither my dad nor i have had a M/t car and i dont know anyone nearby, plus its snowing. lol.
Is there any write up anywhere on how to do this?
