PRO 5.0 shifter should it be this noisy???
Old 12-04-2005, 10:08 AM
ksk1980's Avatar
Default PRO 5.0 shifter should it be this noisy???
Just got the tranny rebuilt. I went w/ the steel shift fork new blocker rings and new 3/4 billet keys(the reason i had to rebuild it). I also put in all new hydraulics and did the drill mod on the master clyinder, put in a new Centerforce dual friction clutch and flywheel. I also changed out the factory hurst shifter w/ a Pro 5.0. the guy at the shop told me it would be a little louder. but this thing rattles like a piece of ****.
Does anyone else have this annoying problem??? are there any fixes?? I really like the feel of the shifter but cant stand the noise.
Old 12-04-2005, 10:21 AM
ls2 bait's Avatar
mines the same way. i still have both rubber boots around the base even. im going to try and put a peice of rubber between the shift handle and the shifter base. it got noticeably louder with the umi short stick so i think thats the culprit-not the shifter itself.
Old 12-04-2005, 10:26 AM
LtownZ28's Avatar
Mine rattled at first because I had the stops adjusted to close to the stick, but when I backed them off a bit the rattles went away. I also got ride of a lot of vibration when I put a gasket between the shifter and transmission and also one between the stick and the shifter. Now mine is almost as quite as stock, but feels a hell of a lot better than the stock one ever did.
Old 12-05-2005, 10:59 AM
convexion's Avatar
I took the stops all the way back. They don't really seem to be necessary for our cars. I don't get any rattling at all and the shifts are smooth as silk.
Old 12-05-2005, 01:17 PM
Joe K. 99 Zeee!!'s Avatar
I put some blue threadlocker on my stops. Also put a paper gasket between the shifter and the tranny. I believe that helped a bit. It's bound to be louder than the stock shifter though. The stock stick has a huge rubber isolator around it.
Old 12-06-2005, 09:19 AM
Demon_Speeding's Avatar
I ran a fairly healthy bead of RTV around the base of the shifter when I installed it. It's been in for about 8 months. Not too noisy at all.
Old 12-06-2005, 03:23 PM
nickls1's Avatar
Mine is noisy as hell too. I was going to back off the stop bolts and make a piece of rubber that will fit around the gasket.
Old 12-06-2005, 03:49 PM
ws6ta444's Avatar
Had the same problem with mine. Then I did some research on it and found a place shiftergaskets.com He has them for our T-56's , just ask him. Think they are like $20, but no noise at all now.
Old 12-06-2005, 04:59 PM
GTObsessor's Avatar
yep.. mine rattles like hell under 2k... above that, nothin.
Quick Reply: PRO 5.0 shifter should it be this noisy???
