master cylinder
Old 12-11-2005, 06:49 PM
NOTAV6's Avatar
Default master cylinder
how do you drain the master cylinder, resevoir and all that stuff while its on the car and how do you bleed it... this is just so i know how when i get the rest of the 6 speed swap done
Old 12-11-2005, 09:01 PM
tippmann243's Avatar
you realy cant, lt1 hydros are a sealed unit non bleedable accept if you use a mitivac
Old 12-11-2005, 10:06 PM
NOTAV6's Avatar
mitivac.... which is a??? nvm found it but how would i use something like taht to get the fluid out of the hydralics
Old 12-12-2005, 12:40 PM
you cant relay use it to get the fluid out, you use it to get air bubbles out of the lines
if you realy want to get all the fulid out, punch out a roll pin and pul the nine out then pump all the fulid out
