can LS1 bolts be used for LS7 clutch install?
just ordered the clutch and wasnt sure if i needed to also make sure i get some bolts ordered. can all the bolts from the ls1 set up be used for the ls7 or are any of them different? i assume the flywheel bolts can be reused but what about the pressure plate bolts?
