Revving car...RPM slow to bleed off. Could it be my Textralia clutch?
1 Post
I have a 02Z28 with a Textralia OZ700 clutch and the iron flywheel (factory style one from textralia.) The last 2x at the track I noticed that when I perform a quick burnout to heat the tires, the RPMS come down slowly after letting off the gas and disengaging the clutch (like a couple seconds slow from 4K to idle.. ) The clutch holds fine at the track, handles all launches and shifts, and drives fine on the street.
So....question is....is the heavy flywheel keeping my engine RPM's from rapidly spooling down when I rev the car? It will do this even in neutral if I rev the engine. It seems that with the stock clutch, the RPM bleedoff in neutral (just revving the engine) was much faster.
Anyhow, $0.02 appreciated.
Kleeborp the Moderator™
That's standard after doing a burnout...there's something in the PCM that holds the RPMs after doing a burnout. I'm not sure what it is, as I don't do many burnouts and don't really care to spend my time looking for it. It has nothing to do with the inertia of the flywheel, as I'm sure the one you have from Textralia weighs about as much as the stock piece.
Hmmm, I always wondered why stock that they did this. My previous car (A4) was very quick up and down the revs after the cam and tune.
Wasn't like that stock, and my current car (M6) also revs down slowly, or slower than I prefer. When I get a tune I will be sure to have them "fix" this issue.
