Clutch Questions
Clutch Questions
I want to get a new clutch when I install an LS6, I will also be spraying a 75-100 shot. What clutch would be best for this set up and how much would it run me? The trans has 36,000 miles on it, do you think I need a new pressure plate and flywheel with the clutch? Thanks for your help guys.
you gotta pay to spray. You are gonna need to upgrade that clutch, how many times you have to upgrade until you find one that works is up to you. The Textralia 700 comes as a kit with a balanced pressure plate and flywheel, clutch disk, slave cylinder, pilot bearing, and their customer service is top notch too. On your '99 you will need to update your hydralics and this kit comes with a new slave.
