clutch pedal going soft??
Old 12-23-2005, 01:32 PM
andypdbz's Avatar
Default clutch pedal going soft?
my clutch pedal is going soft and doesnt actually engage until about halfways.
just last week everything was good and the pedal felt strong and sturdy. does this have to do something with the clutch itself or something else to do with the pedal?
i havent been to the track in a few weeks and i havent been to harsh lately.
any help??
Old 12-23-2005, 02:35 PM
thebatman411's Avatar
I go through that every winter. I remember reading a thread that explained why it does that. I just said the hell with it. I've had the TA for 3 winters and it does it every time. Of course we don't have much of a winter here in Texas, so I only have that problem on some mornings.
Old 12-23-2005, 02:42 PM
andypdbz's Avatar
hmm, so nothing to worry about?
i mean its not cold here in El Paso, the high is 70 today.
so has it been like that all 3 winters? this is my first winter w/ the car
Old 12-24-2005, 02:40 PM
andypdbz's Avatar
any other input?
Old 12-26-2005, 02:34 AM
andypdbz's Avatar
Default clutch pedal going soft??
any help??
P.S. i posted this in the general maintenance topic and got very little response, im hoping i can get some input in here.
andypdbz's Avatar
any help??
Old 12-26-2005, 06:36 AM
blue01ta's Avatar
It could either be your pressure plate going south on ya or a hydraulic problem. Maybe a leak. Check your reservoir. You'd be better off to put this in the manual trans section though.
blue01ta's Avatar
Old 12-26-2005, 07:58 AM
777's Avatar
I sent one to the manual trans section as well. Umm, I'm leaning towards a bad clutch.
Old 12-26-2005, 12:44 PM
camaroextra's Avatar
check simple **** first before you replace your clutch, check for leaks and fluid
Old 12-26-2005, 12:48 PM
Robinator's Avatar
Try bleeding it first off and see what happens.
Old 12-26-2005, 06:12 PM
andypdbz's Avatar
i thought it might be the clutch, but i'll check out the other stuff first.
where can i get a cheap clutch and about how much will it run me?
i might check out ebay but im skeptical about that, btw its an 02 so it has the z06 clutch setup.
and thank you for the input
Old 12-26-2005, 09:29 PM
yup,every winter for me. For me the pedal will feel ok when I jump back into the car after it has warmed up. I remember reading that it happened to others during the cold or cool weather, but I'd like to hear from others as well.
Old 12-27-2005, 03:47 PM
ArcticZ28's Avatar
My pedal does the same damn thing. It has averaged around 40 here as a high and 20's sometimes teens in the nights. It gets a bit better with driving. If it gets worse with driving you might want to reroute the line to the slave cylinder to behind the heat shielding near the bellhousing. Or you could just have gotten air in your lines. Tried bleeding it yet?
Old 12-28-2005, 11:16 AM
andypdbz's Avatar
i'll try bleeding it first, see what happens.
thank you all for the advice.
Quick Reply: clutch pedal going soft??
