how long should the clutch fluid leak out of the bellhousing?
i bled the cltuch, a lot of fluid went in the bellhousing. fluid is still comming out in little droplets being formed on the trans/bellhousing where they go together. i was thinking it was fluid stuck down there in the crack and may take a while to run out of there, but i also want to make sure i dont ahve a leak. is there any way to get it out of there faster? i sprayed it down with water and degreaser but its just so damn frustrating knowing its leaking!
watch the level in the revisior. and if it keeps geting lower then a leak you have, but it it dosent get lower and its still driping then its from bleeding it, it could take for ever for it to seap threw were the belhousing/trans meet
