LS7 clutch install in a C5 PLEASE HELP!!!!!!!!!
Old 01-02-2006, 01:15 PM
DougsfastZ's Avatar
Default LS7 clutch install in a C5 PLEASE HELP!!!!!!!!!
I have the old LS1 clutch out and the new LS2 flywheel bolted to the crank. Problem is when attempting to get the new pressure plate and disk in through the bottom of the bellhousing, it's not clearing! Do I have to remove the bellhousing or is there a special way to get it in from the bottom? I hope I don't have to remove the bellhousing, it doesn't look easy to get those bolts out.
Anyone installed an LS7 clutch in a C5 please help!
Thanks,
Doug D
Old 01-02-2006, 01:31 PM
SIC LSX's Avatar
I sure you have to take the bellhousing off then bolt the clutch,presureplate up to the flywheel then put the bellhousing back on...ps but i havent done one yet.
Old 01-02-2006, 01:32 PM
SIC LSX's Avatar
http://installuniversity.com/install...sity/index.htm
Old 01-02-2006, 01:33 PM
SIC LSX's Avatar
i will be putting my ls7 clutch in this weekend
Old 01-02-2006, 01:41 PM
DougsfastZ's Avatar
I think the bellhousing needs come off. Dan, any posts about anyone doing this?
Doug D
Old 01-02-2006, 01:56 PM
bad6as's Avatar
yes it needs to come off, see the install u link a couple post up
Old 01-02-2006, 02:03 PM
DougsfastZ's Avatar
Thanks guys! I'm on the linked page but don't see a right up?
Doug D
Old 01-02-2006, 02:04 PM
bad6as's Avatar
http://installuniversity.com/install...ch_install.htm
Old 01-02-2006, 02:05 PM
bad6as's Avatar
thats on a camaro, but same idea for the b/h
Old 01-02-2006, 02:07 PM
DougsfastZ's Avatar
Thanks, I've done it in several F-bodies, but the bellhousing bolts on the Vette are harder to get too.
I've heard the intake has to come off in order to get the top bolts out.
Dou gD
Old 01-02-2006, 02:38 PM
Scalpel's Avatar
I did not have to remove my intake to get all the bell housing bolts out on my C5 when I did a clutch install.
Old 01-02-2006, 05:30 PM
DougsfastZ's Avatar
Here is the deal. All you need to remove the four lower bellhousing bolts and slightly pry the bellhousing out about 1/4 inch. Then the clutch will slide right in.
Doug D
Old 01-05-2006, 12:51 PM
MrDude_1's Avatar
Doug D
pry on the bellhousing? that sounds scary.... thoes things are kinda brittle.
Quick Reply: LS7 clutch install in a C5 PLEASE HELP!!!!!!!!!
