How Do You Bleed The Clutch With All Stock Parts?
so how exactly do you bleed the system i just changed the slave cylinder and i know where the bleeder is but do you have to seperate the trans and the bell housing or is there something that i am missing. I am about to finish with ever thing and i was just wondering before i finish bolting the trans and the housing back together.
Like exodus said, throw a socket (10mm I think) on the bleeder through the hole in the trans. Have an assistant push the clutch peddle in and hold it. Open the bleeder. Close the bleeder. Have assistant release the peddle. Repeat until you start to get a firm peddle.
the hose on the end of it is so the fluid dosent sit in the bell housing.
but if you put a socket on it i dont see how a hose could go on it as well.
more info on how you all do it that way?
There is also a hole at the bottome of the tranny to bellhousing that will let the fluid drain out, The bolt size for the bleeder is 7/16ths if I remember right. Gravity bleeding is easy. Just get the car up on jack stands, pump the clutch several times and hold it down. Then have a friend turn the valve open and you will hear a pssshhhh and some fluid may even squirt out. once the whoosh is gone have the friend close the vavle then release your foot off the clutch. Do this a couple times add more hydraulic fluid to resevoir and repeat until you think you are good.
Sooo, if I bleed mine, and it gets NO better?
I opened the bleeder, and let it gravity, and it just all rushed out the drain hole also, my Slave/TOB are FUBAR right?
