My clutch is making a klunking noise.
Lately when I've been driving the camaro when I shift gears it makes a klunk noise. If I get the RPM's up a bit more and shift it smoothly there isn't any noise at all, It's mostly at lower RPM's. Is the problem me or is it the car? I'm not really a lazy shifter but could that be the problem. Or am I just not driving the car right? Thanks
Joel
Joel
mine does it to. I have the ram powergrip HD w/ ram billet flywheel and stock master and slave cylinders. It seems to be getting worse and worse too. the chatter is getting worse also. If you guys are running the ram, have you all called them to see what they have to say??
