T56 all syncros going at once????
Although the clash-in-all-gears is generally an indication of a poorly releasing clutch, it can become permanent if it is allowed to continue . Every clash causes damage to the synchro clutch teeth. After awhile, it will not matter if you fix the clutch - the trans will also need rebuilding.
yea i see wat your saying....im keeping the driving to emergencys only so i dont ruin it even more..
are there any howto`s on how to replace the clutch and the master cylinder for the clutch...
