Spec Stage 2 or RAM Powergrip HD
I was wondering wondering which clutch to go with. Either the Spec stage 2 or the RAM Powergrip HD. they are close to the same price but i do not know which one would be better.
Originally Posted by Farmer2
If you decide on the spec, get the 3 its only a few bucks more.
I went with the Ram and and I am pleased with it.
ive had a spec 3 and the ram pg hd...RAM ALL THE WAY!! Spec just uses a new oem pressure plate so there isnt any added clamping load, where as the RAM is all new everything, not just the disk. I am curious about the spec 2+ though. Id also consider the ls7 clutch with the ls2 flywheel if your not going with forced induction.
