How many running the Textralia clutch?
Just wondering . I ordered mine last night from BYUNSPEED!!! I can't wait all i hear is positive stuff about this clutch even on the Aussie sites!!
If you used the original factory torque specs for the pp, the bolts will back out. There was a tsb about this, because the original factory spec is about 50 or 60 ftlbs less than it should be. My tex grips good enough that I still have a problem with wheelhop powershifting into 3rd gear in the gto.
I still get quite a bit of shuddering with my fairly new Textralia (less than one month), but I've had absolutely no disengagement issues. It disengaged cleanly from day one, far better than the Spec ever did.
