What parts do i need!?
Ok, installing a new clutch, so far i have this on my list.
ls7 clutch
ls2 flywheel
newer slave cylinder
tranny fluid.
what else should i get, or is this is and i am good to go?
ls7 clutch
ls2 flywheel
tranny fluid.
wrencher
Might want to put a new pilot bearing in there also.
Done the drill mod to the line?
Change the trans fluid as well, be good idea to drain it before pulling it out. Some good RTV for the shifter mount, just pour the fluid in the shifter hole B-4 you install the shifter.
Make sure the drive shaft is in also.
yea i have some red permatex, ive ripped the tranny out before to put new synchronizer, and 3-4 shift fork in. Just dont want to get under there and forget somthing.
any thing else?
any thing else?
